hi to all, i have some problems with me Neo V after being uptated to android 4.0.3 version. Now it works slowly , i have to wait 3 sec more to open an aplication and so on etc... I would like to know if is it possible to install my old version of android 2.3.4 instead of the new version !!??? help me please and thank you
reinstall SUS or PCC then restart your computer -> turn off your firewall and/or antivirus -> run flashtool
Downgrade to gingerbread
Remember flashing may void your warranty and you are doing it at your own risk
This is how to downgrade
1)- needed flashtool version 0.6.9.1,,, download here- Flashtool and install it
Run flashtool.exe> Go to C:/ Drive > flashtool > firmwares > delete everything present and exit
2) download rom
Neo V - GB ROM
3) copy the rom to firmwares folder of flashtool
4) run flashtool> click on the flashing icon ( left side below "file" option),,,Select flashmode > ok
5) left side you must see your firmware name and content ,, on the right side mark boxes as
select ok
6)Wait for it to prepare and it will ask you to connect your mobile, follow the steps carefully and connect flashing will begin and flash
Done
28/023/2012 22:23:23 - INFO - Device connected in flash mode
ok, now i disconnect the device and turn it on,,,,,it has always th black screen
even though it vibrates at begining
thank you very much Nabeel finnaly made it !!!! great
after i have done all this things, today i saw that my phones doesn't suppor the mp3 format ,,, what's the problem, why ?
