Hi everyone,
I had recently bought a SE LWW and i have been facing a problem since then that I cannot enable gesture input on my phone. My phone has the build number 4.0.2.A.0.62 after updating the software. I live in India, so I have the japanese and the chinese keryboard options along with the international keyboard. Also inserting the screenshots:-
I'm new to discussions so I'm sorry for any mistake made and please do reply fast.
go to the option above "Gesture input"
in that select """suggest word and don't correct automatically""""
see if it helps
Hi, can't you tick the Gesture input box?
No I can't and its lighter than the others are. The other options are bolder and brighter.
Is the International keyboard one of your selected keyboard?
Yes
You could try software repair, it is similar to software update. You will be prompted that your phone is up to date, just proceed with Repair. Be aware that this will erase phone data completely.
Isn't there any other way to do it and is it available on other LWWs with the same firmware??????
I am not sure if there is another way, but a software repair should be able to resolve a software issue.
I cannot afford to lose all my phone data so I wont do a System repair
Can anyone from sony reply into this???????????PLZ
