guys....can i ask if will there be bad or something willl be corupted if i left my phone no charge?
i left it last night at below 10% didnt know someone is calling.....
i know this is alright on other mobile phones....but i not that exp with OS phones...or android....
will some file corrupted ? or like damage the programs?
i m charging it right now....at 90% i on it its alright alot of missed calls...
any advices?
hi @silver99 no nothing would happen like that I've done it many times with my xperia mini nothing happened...and even no damage would occur to your battery because if it's charged upto 100% then the battery itself discharge a bit and again recharge to extend the battery life so no problem....:-D hope ur clear now... and don't forget to mark my answer as correct and helpful..!!;-)
as santam said
enjoy
battery is not harmed in anyway
your android is smart enough to manage its battery on its own
when your mobile reaches 100% it stops charging on its own no matter if the charger remains connected to it
