Hello everybody!
I'm having troubles with my minipro. The screen and the keyboard lights are not working with the amb light sensor. (I've already test the sensor itselfs - using the service menu - and it is working)
Anyone could help me? Thanks!
Eric
Repair your phone via PCC OR SUS
PCC
(PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to). Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
Pc companion link http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download it and install it on your pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
both the links are same
Don't forget to mark the Correct Answers and Helpful Answers
PCC
or
also , restart your device first , if restarting does not helps then try the above suggestion..
