Hey guys, have you ever been to MESSAGING>OPTIONS>SETTINGS>NOTIFICATION TONE. Scroll down the bottom, you will see a JOIN HANGOUT tone. I have like 12 of those on my phone and just curious, if i could delete 11 of em? Hahaha. It's like a spam ringtone
Yes,i have them.I could find them and also delete them,they are in notifications,you can find them with a file explorer.But there are only 2 files,and in the ringtone menu they appear about 8.Anyway,they still did not dissapear from there but i cannot play them anymore,maybe after a restart they will be gone.
i think those ringtones cannot be deleted,they are from the phone software.But if the phone is rooted,maybe then can be deleted.
Do you have them on your phone?
souds good as a ringtone my friend haha
Have you tried it?It seems it comes back after being deleted,i deleted them and after restarting the phone these ringtones are still there.They are from the operating system.
I suppose it's gonna be there for a long long time. Hahaha. Thanks alexdon!
You are welcome,it seems they will make us happier in bad times:smileylaugh:
