Hi there,
Standard SmartTags pack contains 4 tags of different colours.
If I get a second set of 4, will each be recognized as unique, or will the XPERIA see the two red tags as being the same, etc.?
As I understand there are only four unique NFC tags available at the moment. So if you would get another red tag it will act the same as your old red tag.
Thanks -- good to know.
late for me. I have 3 pairs of red and black.
Is there no possibility of changing the internal code of the tag? Though they are red, they could be different.
Can not record something in them?
They already have registered a unique code, and the phone reads it and loads the right profile you've set up previously?
At the end is impractical. It's like if you have 4 profiles set up and you have 4 icons on the screen. Faster and simpler.
Thanks.
I have to sell 2 pairs of tags.
The spart tags are no more than URL nfc tags with an url liveware will reconise.
You might want to look at :
(Blue): semc://liveware/A1/1/NT1/1/smarttags1
(Red) : semc://liveware/A1/1/NT1/2/smarttags1
(Black): semc://liveware/A1/1/NT1/3/smarttags1
(White): semc://liveware/A1/1/NT1/4/smarttags1
Great.
I have configured red and black tags as white and blue.
Can I create new ones in order to have 6 different?
Thanks
I tried semc://liveware/A1/1/NT1/5/smarttags1, but it didn't work
Would be a nice update to liveware (hint hint sony !)
yeah, this would be great!
i bought the Xperia Z yesterday and got 2 tags.
now i want to buy the set with 4 tags and then, 2 of them would be useless
Buy the second package, (ie purple, green, gay orange)
and it's semc://liveware/A1/1/NT2/1/smarttags1, memory serve me right.
You can use this app to rewrite tags
https://play.google.com/store/apps/details?id=com.vexedbadger.smarttagmaker
