Yesterday I updated my ray to ics...after 2 hours if successful updating,while installing a application mobile got switched off and never turned on again.what could be the problem????
ok then, just repair it with SUS
did it turn on at all after the update was over?
just run SUS again to repair it
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Ya bro..i used it for 2 hours after updating....while installing an app it got switched off
Hi ,
Even I faced the same problem yesterday. I have xperia neo v. I can see there is an update flashing on Sony site saying that there is a proble with ICS update.
Please help me in resolving the issue and get my phone started.
