Hello Guys,
Two days before I gave my neo v to Sony service center ( Bangalore) for ICS upgrade. They said ICS build having problem, better i ll update the same version(2.3.4) which makes mobile performs better. After updating the same version everything is same as before only some camera options are not availble, which I used earlier ( Scenes, Exposure Value, White balance, Image stabilizer options are not available now).
Please help me to get back those options to use my Neo V camera better....
Oh great, thanks Nabeel
