i accidantly press factory data reset and all my phone contact gone pls tell me how can i recover my contacts. my phone is xperia s.
Whatever the reason that you deleted phone contacts , you still can resore them from phone memory or SID cared, the key is which recovery tools is you use, you should ues an effective tool to do .
i accidantly press factory data reset and all my phone contact gone pls tell me how can i recover my contacts. my phone is xperiahow to recover deleted phone contacts
It can't be done, after a factory reset there's no way to restore them, unless you backed them up with a cloud service.
You need an Android recovery tool to get back your data.
I wanted to delete 1 phone # and all my contacted deleted my phone is samsung.
please provide advice on retreiving contact list
