hi friends
today only i came to know about the ics update......when i checked in net its said that use pc companion to update.....so what should i do??? just connect to pc and click update in pc companion??? please help
thanks
i saw many peoples comments like xperia u hangs a lot after ics update......is it true?
thats why i have this:http://talk.sonymobile.com/thread/44278
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
thanx man 🙂
u r welcome.
Ah i see People already helped, next time better
Hey I need your help...i installed ics..but now my gallery shows all the photos together..that is jumbked..i saved different photos in different folders and copied but its all jumbled what to do??? Earlier with gb photos were arranged inside folders..this is not good..they are arranging on their own on the basis of date...please tell me how to change that??? Now also when I change the view they are showing folder wise..but at the beginning its always jumbled..any way to make the folder view permanent???
nopes, its like that in ICS. I use a separate app QuickPic.
How to take screenshot in ics??? Earlier with gb it was an option in power button..but now its not there...
