hi friends
today only i came to know about the ics update......when i checked in net its said that use pc companion to update.....so what should i do??? just connect to pc and click update in pc companion??? please help
thanks
How to take screenshot in ics??? Earlier with gb it was an option when we press the power button...but now its not there
either PCC or SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
unrelated topic, if you have some time please check this thread
thanks bro
so just connect to pc and click update now in pcc?
and what is this sus?
sus it's a lot faster and reliable than PCC
thanks very much
am downloading sus now.....from the link you gave me
just run the file after downloading?
you have to run it to install it
Install ICS:http://talk.sonymobile.com/thread/55225
RAM boost:http://talk.sonymobile.com/thread/44278
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
right now am installing using sus.....while downloading it stopped 3 times in between...still downloading....
ya it stops and then continues, as long as the net is ON, the connection is fine, its alls OK.
thanx bro...so no problem with this stopping right?
