if you got the apk then
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
transfer the App/apk/game to your SD card, use OI file manager to find it -> tap on it -> install it
you need to tell us a bit more, did you downloaded it from the market? or how?
if you got the game from the market it will be installed by itself
You need to
An easier way to install apks
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
thanks dude got to installed alot of games :smileygrin:
anytime
