Hye....i want to ask something regarding my beloved xperia ray....i just bought it,just for 3 weeks i guess...
yesterday i change it memory card,...(i have 1 spare memory card)when i want to start the phone,the screen blank....there is a light but no Menu's appear...i don't know what the problem is..can someone help me,please???
I don't know why your phone its acting like that if the ONLY thing you did was to use a different micro SD card. you will have to return to the store and/or contact SE repair center
http://www.sonyericsson.com/cws/common/contact?cc=gb&lc=en
If you remove the SD card, can you start the phone again? It sounds like your second SD card might be broken.
Nope,i can't....i have tried several times already...it's still can't switched on.....when i press the on/off button...the Home button just gives out a red blink....
you need to charge your phone, that red blink means that the battery is dead, try the wall charger or the computer, if the LED doesn't light up yellow orange or green then try a different micro USB cable, it doesn't have to be sony ericsson
once you get some charge on your phone use this to repair it
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
ok...i have connected it to the pc...but it doesnt charge it...still blank...the red blink still appears...how's that????
i have tried using another usb...it doesn't work also...='(
seriously...the ONLY thing i do is change the sd card...i took a good care of my phone...it's never fell off my hand ok...it's sounds weird but it happens to me...i just bought it...idk if its my fault or not...
the phone was probably faulty, it happens, just contact SE repair center or the store where you bought it
