Data usage warning is showing in my notification bar and i didn't found any way to turn it off, its very annoying, waiting for suggestions
no its not restricted to any network brand like AT & T or something else,
how odd, so it was never locked to a carrier?
hi karan....
to disable data usage warning...first u have to enable mbile data..!
hope dis is helpful..!!:smileyhappy:
Thank you guys
Hi All,
I have got this issue in my ICS and fixed.
Follow this steps.
1. Settings--->Data usage --> Enable Mobile Data,
2. check Set mobile data limit.
3. Drag the horizontal Orange Line having "warning" to top with a data limit that your phone is not yet reached [eg : 10GB] .
4. Uncheck the Set mobile data limit.
5. Disable Mobile Data
Warning will disappear.
Please find the below image for horizontal Orange Line having "warning"
