Data usage warning is showing in my notification bar and i didn't found any way to turn it off, its very annoying, waiting for suggestions
Firstly you need to enable data transfer then you will be able to set or remove data usage warning and limit. Or you can change starting date of data usage.
settings > data traffic > uncheck the data limit or set it higher
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
thanks for the reply, can you specify the path properly? coz there is no option called data traffic in settings, Data usage is there. There is no option in this section to either turn it off or to extend
typo
data usage
you should be able to see
Set mobile data limit
can you post a screenshot of the message?
Even if i open the options in this page there is no way to clear this
ok that's odd that you don't have that option. can you post a screenshot of the warning? I'm starting to think that it might be a network/carrier setting.
Hi, its not a network problem. Below is the screenshot of that warning, when i click on it, it takes me to same settings screen
Tapping on that notification will take me to below screen same as in settings
do you have a data limit (2GB, 3GB, 5GB data plan)?
yea, 1GB pack
there you go, that's why you are getting the notification, it seems that you are either at or close to your 1GB data plan limit. so it is a notification set by the carrier, is your phone network branded?
