Hi everybody,
I made the update to android 4.3 and since i cant play my HD games with data placed in Obb
each time i run the game downloading data apears ...
any idea ?
try to reset to factory your phone
did you do this after update?
i have no problem with games..games that even wont run on 4.1 now run perfectly
thank you now the trouble is gone but it takes time to reinstal apps and configure other stuff , after all it worth spending time on it
