After updating to 4.3 sound level is stuck in half level with headphone. I couldnot increase it to full by any means. What should I do. Please help.
BINGO!!!!!!!!!! Solved the problem
With headphone connected pressing the volume+ button gives an option showing that weird message that hearing to volumes above this level may affect your hearing and then it shows the option to increase the volume.
Ah!!!!!!! peace
Have you tried clearing data for smart connect in settings-apps-all?
Yes I did that. After doing this an option comes to configure the action where I selected the sound to be full with application start. But it didnt work. I think there is something saved in the settings which is responsible for this. How should I fix it ??
That should have helped.Try to force restart your device(power button+vol up until the phone vibrates).
Force restarted the phone. Still the problem exists.
