if i upgrade my phone to ics n if internet connection breaks or something happens during the process, will my phone get damaged permanently? is it better if i give it to sony service center itself for upgrading? and what is flashing? is it the same as rooting?
if your internet connection stops working or there's a power outage, your phone will get a exclamation mark, to fix it you could try to use SUS or PCC if that doesn't work you could send it to get it repair with sony
http://www.sonymobile.com/global-en/support/contact-us/
You can't root 2.3.4 build number .62 unless you unlock your bootloader I don't recommend this if you don't know what you are doing, you could permanently damaged your phone.
flashing it's quite simple, if your internet stops mid update or power outage mid update and neither PCC nor SUS work and you don't want to send it to Sony and be w/o a phone for 4 to 6 weeks you could flash your phone and repair it.
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
and this might be useful
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
i just called up sony india cc..they said i couldnt get my phone updated by the service center itself..i thought of going there coz pcc wont work on my comp..but thanks to u i found out about update service..so finally just want to be absolutely sure, i wont damage my phone completely unless i try to root it n mess it up right?
I'm certain, again you can always repair it
thanks a lot!
Anytime
btw how much time does it take to ugrade from gb to ics? net speed is 1Mbps(around 130KBps) n i will be using update service..
it's about 200MB
