can I ask what is the difference between SUS update (http://www.sonymobile.com/gb/tools/update-service/) and PC companion? doesn't pc compainion get the required updates?
Hi, SUS is solely for updating software and that is it. PC Companion has more options other than software update.
Basically, you can use either one for software update ....
ok thanks :smileygrin:
No problem ....
