I'm Done Everything, Drivers are installed, Copied Customization.ini in Root folder of emma, Connected Emma with network & My phone connected with Flashmode (Blue Light on ear piece also). But Phone doesn't detecting in App, no changes in emma flashtool.. i can't flash firmware.. Please Help me.
My device Details
Phone : Sony Xperia T3 D5102
I need to know other Think too, Some others says that, After Flashing Firmware Others Phone Stuck at Sony Wave [ Boot loop ].. It is possible to me [ Bootloop ]...? If stuck in Bootloop what will do next? I need to know detail about it. Thanks....
Why are you using EMMA instead of Flashtool? are you aware of the consequences of unlocking the bootloader?
help sony D5102 update system
