From one day to another my xperia J screen is black.
Pushing the Power Key results in flashing up of the back key, home key and menu key as well as the social network notifier light, but no reaction of the touchscreen.
When plugged in the LED still indicates the battery level (red-green).
I can remove and insert the battery and after pushing the power key again the phone vibrates once.
I already tried a software-update via Sony PC companion / USB, with no effect.
Any help is appreciated!
Thx Simon
So you have tried to charge the phone for about 2 hours and perform a software repair?
And you have made it clear that the phone was completely off while doing the procedure?
Did you get your xperia back to working? I have the same problem and I don't know the cause.
Mine is the same Problem . So Did you get some solution? Please
