I'm Done Everything, Drivers are installed, Copied Customization.ini in Root folder of emma, Connected Emma with network & My phone connected with Flashmode (Blue Light on ear piece also). But Phone doesn't detecting in App, no changes in emma flashtool.. i can't flash firmware.. Please Help me.
My device Details
Phone : Sony Xperia T3 D5102
No you do not hold power button - your phone must be off, don't touch power button at all then hold volume down and only that button/key then connect your USB cable - I repeat your phone must be off and do not touch the power button at any point
Is your bootloader unlocked? as this software will only work if your device is compatible and your bootloader is unlocked
A blue light on my devices means that you are in Fastboot mode not Flashmode - You need to have your device switched off then you need to hold volume down then connect your device
Yeah, @ the time Volume Button Down Holding my device vibrates 2 times and boot up normally. Not going to flashmode.
I don't know why it's not working - You are either doing something wrong or your modifications are causing a conflict - My device is modified also with dual recovery and I have no issues getting into flashmode - but it should still be able to enter Flashmode assuming your device is fully switched off then holding volume down connect your USB cable
No need to turn on? I'm doing this way [ hold power button and at the time of displaying sony logo connect usb and press and hold volume down button ] ....
