Hello all,
My recent Xperia Pro appears to have a scratch in it's display glass, deep enough to be able to 'break' the light. I now need to replace the glass of my touchscreen. I am insured, but I can't lose my phone for 3 weeks just for a simple display glass replacement that can be done in a few hours. The trouble for me is, where do I buy a display glass for an Xperia Pro? Just the display, not the whole package (inc. touchscreen or such) 'cause my touchscreen itself still works fine it's just the display glass that contains a scratch.
Any help will be appreciated
Kind regards
how is it that you scratched the LCD but not the digitizer/touchscreen?
here you go
http://compare.ebay.com/like/190635131869?var=lv<yp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
Holy @#$%! That much for simply replacing my front glass? Redicolous, I just need to buy the display glass and I can do it myself. It will save me around 3 weeks.
I don't know, the pixels still work, but the light is breaking the clear view so I assume it's just the glass.
the "display glass" is not just any glass, that's the digitizer.
Can you take some pictures?
Sure, please give me a moment.
Well no, I can't 'cause the cam of my PC isn't working correctly. I'm sorry.
whenever you get a chance take a picture, I just don't quite get why the LCD got scratched and not the digitizer, or maybe is not a scratch but dead pixels
