Hey people at my help out there....please help me on the USB OTG feature of xperia u as the phone initially Doesn't comes with a OTG cable then from where to buy it nd then how to connect a proper pen drive to this Phone...is it really possible or its just a rumor..as some users said that it doesn't has USB OTG support as they Tried connecting but nothing happened..I have seen a video on YouTube in which the sola was connected to a Pen drive but Wat about xperia U...Please describe in detail because USB OTG is one of the most important Features due to which I will buy this phone...please answer as soon as possible...
you can get it here
http://www.amazon.com/QVS-CC2218C1M-Micro-USB-Cable-Phone/dp/B0026TWMNQ
USB OTG it is indeed supported by both 2011 and 2012 Xperias but for the 2011 Xperias you need to root your phone.
you can get it here
a pendrive might not work since it require more voltage
just like any micro-usb cable will work with your Xperias, the same is true to this, it has to be a micro-usb otg, I recommend ebay or amazon
don't spend too much money on the cable, if it's more than $2-4 USD its over-priced, as to a nokia phone that support this, I'll have to look into that.
Yeah plz see to it nd tell me a Nokia phone....nd plz advice me that shall I buy a blackberry playbook and a htc explorer or a xperia sola...??
Yeah plz see to it nd tell me a Nokia phone....nd plz advice me that shall I buy a combo of blackberry playbook and a htc explorer or just a xperia sola...??...I can give a chance to xperia u also...plzzz tell..
I wouldn't buy any blackberry
