Should I remove the cover of the back camera or is it a protector? Thanks
this is the problem with most of the people... They dont remove the lens cover & complaint of getting blurry images with flash...
Wierd part is that Even the Seller;s are not aware of this...
if it has a tab, then you can remove it.
yes it has, thanks
where can i buy lens cover for xperia ray?
ask in the ray forumj
i've seen some "camera lens protector" around online sotres like ebay.
here are some tips to keep your lens cover good
never ever try to wipe it with anything
a gentle blow be used to dislodge small dirt.
To be honest, it took me a long time scince I actually found out it had a cover on top of it.
There was a little crack in that cover, and I was worrying a lot about it, because I tought the glass was broken, so when I wanted to check the damage, wich means I removed the back panel of the phone, I saw a tab on there, removed it, and I saw the "crack" I saw, was just something in the cover.
I feel so stupid telling this xD
