Hello guys!
My Xperia U got froozen while I was rearranging my icons on my homescreen, so I pull out the battery, and put it back in, but when I was restarting it, it shows the Sony logo, but that's it!
i've pulled the battery back out, back in, again the same
without sim, the same
with sim, the same
while charging, the same
whlie not charging, the same
I think I've done everything possible
It also won't connect to PC, or PC Companion
My phone is NOT rooted and has the OFFICIAL ICS version on it installed (so no custom rom)
what should I do? because it's basically death right now
(btw, Sony, if you are reading this, I'm getting pissed a little bit more every day)
edit:
mistyped "rearranging"
SUS works entirely in a different way...
Unlike PC Companion, SUS works under S1 Download mode of your phone instead of normally connect your phone like you used to...
SUS also installs a specific driver so that the computer can recognise...
In other words, SUS is a backup plan for PCC...
Note that: Update Service works when your phone is turned off!
Regards,
Trubo
repair it with SUS
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
RELATED topic, if you have some time please check this thread
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
It doesn't connect to my computer, so I can't use update service, pc companion,... because the computer doesn't recognise a device
Regards,
Trubo
Okay, that didn't work on my pc, but it did on my dad's pc? (made me say: dafuq?)
anyways, it worked, didn't have a backup, so that quiet sucks, because I lost everything now, but at least my phone is back in town!
Just a side question, does anybody know what occured this problem? I mean, if the phone is stuck, you can't do anything else then removing the battery right?
