When pluged into a computer, it turns on and off repeatedly and cannot connect to usb. When pluged into a wall charger it turns on and off repeatedly also. I have updated the firmware and reinstalled several times, i have also "tried taking out and putting the battery in again" as i saw in another thread. i have also tried this "
Have you tried using more then one charger? If not, please try to see if the problem remains.
If it does it sounds like it would be wise to try performing a repair of your phone's software.
You can easily perform the interaction with our program Sony PC Companion, available for download from the link below." . i cant find any further information specific to this phone either. Is it supposed to be doing this can you tell me? It will always shutdown when pluged in, this cannot be normal. Many thanks, D. Wheeler
you can try this
connect your phone to a wall charger > press and hold the power button & volume up for 5 seconds or so (until the phone it's off) > let it charge for 1hr > after 1hr try to repair it with SUS
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
remove the Sim and SD cards > repair it with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
This would be fine but it recomends that there is at least 50% charge , this suggests that starting with a lower charge will cause problems. it doesnt charge verry well at all while it is repeatedly turning on and off. should i continue at a low charge or wait for it to eventualy charge?
you can try this
After doing as you sugested i got 3 red flashes on my phone as i tried to turn it on..
after you left the phone charging for 1hr?
well it turned on now and was on 1% and it appears to be charging , will update. Edit:Thank you muchly , is working fine now
Hi
We had the same.
The phone had the green LED on when we plugged it into the wall charger, so assumed it was fully charged.
The LED would flash red 3 times when we tried to turn it on when unplugged. nothing when plugged in just the green LED.
We have numerous chargers Sony and HTC and numerous cables all did the same, green LED and no response.
Tried it on the usb on the PC and again got a green LED but after a minute it changed to a red LED and the charging symbol on the display.
Seemed to charge ok off the PC and was usuable after about 4 hrs. Switched on ok after long press and booted fine.
I mentioned in another post I think the battery is very flat and for whatever reason needs PC to start the charging process. I'll see tomorrow if it will charge of the mains chargers.
HTH
Merry Chrimbo
BimB
keep us updated
Hi the solutions above me from "uliwooly" worked perfectly
haha merry christmas :smileygrin: , and hope the update trick will work for you guys!
