I recently added addresses to 4 contacts using PC Compannion on my lap top. When I then sync'd my phone, all the addresses were added to the last contact I'd updated instead of each individual contact. How can I avoid this happening.
Best regards John
go to the market and type my phone explorer, or
click on that link -> log in -> and send that app to your phone
I'm sorry to hear. Are you syncing via SE Sync or Gmail in PC Companion?
If you're syncing via SE Sync I suggest that you export you contacts from SE Sync to Gmail to check if they same problem occurs syncing with Gmail instead or vice versa.
Hi, thanks for your help. I downloaded the program 'My Phone Explorer', but it will not recognise my phone. I've tried all the connection options, i.e. Wi-Fi, Bluetooth, USB etc, but in all cases I get similar error messages as follows.
Connection to phone could not be established
Phone could not be Identified
or
connection to phone could not be established
Failed to obtain IP address of phone
I could not find any way around this.
Have you any advice please?
Regards John
do you have this app on your phone already?
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&feature=search_result
No, I have it on my PC, How do I get it on my phone?
Thank you, it's all working well now.
Very best regards John
anytime
