can i create something like a folder to group my apps into games, utility and ect????
it seems that you have a lot of questions
long press anywhere or press menu (add) on your homescreen -> tap on folder -> then just drag the apps there
another cool way to do it, put an app/icon on your homescreen, then drag another app that you want in the same folder, the phone will ask you which type of folder you want to create
http://talk.sonyericsson.com/message/22126#22126 You might want to see Sushidushi's suggestions from this thread.
well... thanks for answering all my questions then=) still new to the phone u see=) luckily i found out this forum and helpful ppl like u. XD
thanks dr chris! her suggestions are great=)
and there are myriad apps that will sort and organize your apps
https://market.android.com/details?id=com.utility.autoapporganizer&feature=search_result
https://market.android.com/details?id=com.google.code.appsorganizer&feature=search_result
anytime
Good stuff!
thanks again uliwooly=)
