Dears,
clearly from the topic that I can't find a decent car kit for my Xperia S, the one I had CK100 is not suitable with the phone because it presses the volume button.
is there any plans to release a new car kit from Sony , or is there any third part accessory I can get suitable car kit ?
awaiting your replys.
Regards,
We have no officially compatible product for this and I have no info saying there are plans to release something either. This doesn't necessarily mean we will never release something like it. It basically says I just don't have any such info.
I'm sure there are 3rd party manufacturers that can help with this though so I suggest you focus on finding something from this market.
Have a look at this site, I think they can help you.
http://www.brodit.se/reseller.html?pn=cont&sm=fd
What do you think about this forum? Let us know by doing this short survey.
