im using a xperia neo v . and i've been trying to use the usb on the go function to mount a pen drive to my phone. it does not detect the pen drive. it detects USB mouse and USB keyboard. but USB mass storage devices are not recognized. can some1 help me to fix this. thanks
USB OTG in Xperia neo V is limited for I/O devices only (for unrooted phone). Since USB storage require high Power for transferring data between the devices, its not possible to use pendrives directly with otg cable on Neo V.
To use them you need to root your phone so that you can make the decision and control of the device.
you can connect Pendrives only to Rooted Neo V, but this me void your phone warranty .
Don't forget to mark the Correct or Helpfull Answer.
you need to root your phone for this to work
unrelated topic, if you have some time please check this thread
why isnt it detected by the liveware manager?
thanks alot
