Hello!
A bought my Xperia Ray 3 day ago, and after the update I'm still wondering is there any way to turn off the camera shooting sound. On the camera settings there is only 3 options: Sound 1, 2 and 3, there is no mute, or sound off....So if there any way to mute thoose sounds I'll be very greatful.
I'm not install any app for the camera, only official SE update.
Thnak's in advanced:smileywink:
That is correct; some regions have removed the ability to remove the shutter sound due to privacy laws.
http://talk.sonyericsson.com/message/60925#60925 Link to related thread with possible solutions.
dr chris link has a good solution
well you cannot do anything other than turning your phone to silent mode..
Turning my phone in silence mode didn't work to sound off camera shooting. The same anoying sound when I'm going to shoot. I saw the link, probably I'll try some appss(some said that Vignette is good and Quick settings, but if there's any way without apps, it will be good)
Hi, I remember reading something about turning off camera shooting sound is not allow in some countries.
Do you remember which countries? I'm in Bulgaria. If it has such thing that will be very stupid...
I do not know which are those countries, but I think it is due to 'privacy law' (something like that).
Japan and S.Korea among others.
