A general query: I cannot find a command to mark this forum read. Is there one? Many forums have the ability to change all the read posts to normal font and leave the unread posts in bold font.
Hi, I unintentionally found and noticed that there is indeed something similar.
Go to your favourite community, click Discussion tab, you should be able to find see some posts are in bold (unread), some are bold with the word 'Updated' (new posts update) and normal font (read). Of course you must be login.
Thanks. I was always in the Overview tab where this option is not available.
Welcome. I guess it is worth spending some time exploring this Support Forum, you might stumble upon more 'surprises'. Just a some clicks away ....
