plz i had got newly the sony ericson xperia arc s.but i have a problem finding the call blocking password. so how can i get it plz
I DO INSTALL THE CALL FILTER.IT'S MORE SUITABLE THAN NUMBERS FOR ME.BUT I JUST FIND ADD LIST FOR BLOCK CALL NOT FOR ACCEPTED CALL.BECAUSE I NEED JUST SOME ACCEPT AND THE OTHER I WANT TO NOT ACCEPT THEM. CAN U HELP ME MORE PLZ
just got to the settings, it's quite simple
Dear cattymano what about if I forgat the password and when trying call there is a massege apear to me (Outgoing calls are retricted by FDN) in this case what can I do.
Thank very much.
Hope I get replay as soon as posible.
Hi, I want to block my husband and his...shemale numbers on my Xperia Z. I can get into the call barring settings but
have no idea what the password is it asks for when I select all incoming...can you helpplease?
