I have xperia SP recently bought. I have been using the phone from 2 weeks and now I see some dust particles inside the screen how can I remove it?
Have you apply an extra film protector? if you did perhaps the dust particles are between the ASF (Anti Shatter Film) and the new film, the ASF its pre-applied on most if not all Xperias, this film it is not scratch resistant, so it is wise to apply another film, if you don't have an extra film protector then you should stop by a Sony repair center
No I havent applied any extra film protector. I find the dust particles inside ASF.
Then you MUST take it to a Sony repair center
