I JUST BOUGHT THE XPERIA ARC S ITS A WONDERFULL PHONE BUT IM FACING TWO PROBLEMS ........
1 ) THE PHONE HEATS UP NEAR THE TOP PART WHILE ON WIFI OR PLAYING GAMES TEMP REACHES UPTO 37-38 DEGREES...
2 ) AFTER OVERNIGHT ON CHARGE THE BATTERY LASTED FOR ABOUT 8 HRS........DISPLAY USING ABOUT 65 % OF BATTERY
PLZ HELP N TELL ME IF THE PHONE HEATING UP IS NORMAL
This has been discussed a few times here. I'd read this: http://talk.sonyericsson.com/message/70285
As for the screen using most of the battery, consider turning down the brightness.
EVEN IF IM KEEPING THE BRIGHTNESS DOWN TO 5 % IT STILL SHOWS DISPLAY USING 65 % BATTERY
I imagine display will always be the highest battery consumer (it is on my Xperia ray). You may notice a decrease after a few days, since your phone is brand new, likely you are using it more then you would in a normal day situation.
After 5 hours off the charger, my display is using 32%, Grooveshark (music app) is using 24%, and Cell standby is 14%.
