Hi there,
since a couple of days Im a proud owner of an xperia active.
Now afzer playing around for a few days I would like to set it up propper.
For that reason I would like to import my Blackbery Contacts into the Active.
-So far I did not have any success....:smileysad:
How can I export the local BB Contacts into the active.
The BB is complete over the air with the company I work for and I dont have a Sync Software for it.
Any ideas ??
Thanks in advance
Sionnach
Can you save the BB contacts to your SIM? Then you can bring them over to the Xperia active.
Otherwise, they will need to be in Outlook or GMail, to sync any other way.
