- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello Everyone,
I am a new user of Xperia M dual . Just wanted to know best app that can boost up RAM usage. Since RAM is 1GB... the processes generally reaches that capacity and then I am not able to use the phone efficiently. Also the games like temple run starts hanging up....Have installed RAM booster but not much happy with the same
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do not use task killers,phone optimizers,free RAM apps.Just force close apps you do not use(you can even disable them in settings-apps-all).Also,restart your phone regularly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Use 360 safe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
But when we force stop it.. it gives an error that the app may mishave... do u want to contine?? So does it start misbehaving actually if we force stop??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The apps will restart by themselves later,anyway.And you can disable the ones you do not use.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So there is no other solution than disabling the programs?? so to boost up ram usage i wil have to diasable some of apps right???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes,that would be a good option.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Indeed.
