hey guys can samsung kies and pc companion work properly on one pc.I'm asking because i want to update my xperia m to 4.3 and i have installed kies for my samsung phone.Are there any problems with the installation??
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
It's hard for me to say if there are any problems to have these two programs installed at the same time since I have never used Kies. But I have never heard that it should cause any issues and I cannot see why it should be a problem.
If you start to experience issues, just make sure that Kies is closed when you are using PC Companion and it should not be a problem.
thank you!I updated my xperia m to 4.3 with no issues.Again thank you for your help!
Nice to hear, thanks for the information. Anytime.:smileyhappy:
