Hello Everyone,
I am a new user of Xperia M dual . Just wanted to know best app that can boost up RAM usage. Since RAM is 1GB... the processes generally reaches that capacity and then I am not able to use the phone efficiently. Also the games like temple run starts hanging up....Have installed RAM booster but not much happy with the same
Do not use task killers,phone optimizers,free RAM apps.Just force close apps you do not use(you can even disable them in settings-apps-all).Also,restart your phone regularly.
Use 360 safe
But when we force stop it.. it gives an error that the app may mishave... do u want to contine?? So does it start misbehaving actually if we force stop??
The apps will restart by themselves later,anyway.And you can disable the ones you do not use.
So there is no other solution than disabling the programs?? so to boost up ram usage i wil have to diasable some of apps right???
Yes,that would be a good option.
Indeed.
