Junte-se e partilhe a sua experiência!
MAP (message access profile)
SOLUCIONADO
Oldnick2
Visitante
Does the M4 support MAP and if not is there a way adding the profile etc.?
1 SOLUÇÃO ACEITE
Soluções aceites
Christofer
Vencedor
Hi @Oldnick2,
Welcome to the community! Slightly_smiling_Face
Based on the information available in the white paper for Xperia M4 Aqua, MAP is not supported.
As far as I know it is not possible to add this profile manually.
Ver solução na publicação original
7 RESPOSTAS 7
Christofer
Vencedor
Hi @Oldnick2,
Oldnick2
Visitante
Many thanks - I thought that was the case - Very disappointed with the M4 but locked into a 24 month contract.
Christofer
Vencedor
You're welcome! Sorry to hear that you are disappointed with your Xperia M4 Aqua though. Please let me know if you have any further questions.
Billford1
Visitante
I believe it does have MAP.
It will show text messages on my car, Ford Sync. It can display the text message or read it out.
Christofer
Vencedor
Hi @Billford1,
I will look into this and let you know as soon as I have confirmation.
Christofer
Vencedor
I can confirm that Xperia M4 Aqua doesn't support MAP. If a device supports MAP it will be mentioned in the device's white paper.
Billford1
Visitante
This screenshot shows the M4 Aqua has MAP
