Does the M4 support MAP and if not is there a way adding the profile etc.?
Hi @Oldnick2,
Welcome to the community!
Based on the information available in the white paper for Xperia M4 Aqua, MAP is not supported.
As far as I know it is not possible to add this profile manually.
Hi @Oldnick2,
Many thanks - I thought that was the case - Very disappointed with the M4 but locked into a 24 month contract.
You're welcome! Sorry to hear that you are disappointed with your Xperia M4 Aqua though. Please let me know if you have any further questions.
I believe it does have MAP.
It will show text messages on my car, Ford Sync. It can display the text message or read it out.
I can confirm that Xperia M4 Aqua doesn't support MAP. If a device supports MAP it will be mentioned in the device's white paper.
This screenshot shows the M4 Aqua has MAP
