- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Error Camera may be in use by another application
I'm experiencing this error on my M5 at the moment.
"Error
The camera may be in use by another application. Please close the other application and try again."
I've tried rebooting, factory reset,safe mode, and clearing data/cache of camera app. Nothing works!
I just got my M5 and I'm disappointed by this.
The camera worked fine the first week only. I haven't done anything to my phone nor did I drop it to cause such issue.
Can someone help me out?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all , I cured this on my M5 by DISABLING LOCATION in camera settings could be this easy for everyone .
Hope this helps all
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Where is Sony support or Jake-SonyXperiaSupport no answer, no fix to this problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem ?????sony should find solution for this I buy this phone m5 for it's camera !!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem with my z5, it was sent off last year as it was overheating they said there was nothing wrong with it even though it burnt my leg through my pocket, and few weeks ago my camera stoped working front and rear with the same error as you guys, if we cant get anywhere here maybe twitter, facebook, could help if enough of us complain maybe even stop another fool from buying a so called premium handset.
sony z5 premium = clown shoes!
how many posts will it take sony?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
is jake @sony even real??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have exactly the same issue now...Tried everything possible but no luck. How is there still no solution for this? Really dissapointed in Sony. It started with my phone overheating, then my front camera stopped working and the then I got the error Camera may be in use...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Carlin7000 wrote:
I have experienced this problem. It stops bothering when one disables Google: "hello Google" Try it, disabled and enable so that you can establish cause and effect.
Tried this on my L1 and doesn't resolve problem for me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Abhiroj wrote:
In case , if you are using clean master, I would advice to remove it , and then restart the phone. I had the same issue. Worked for me!
Glad it worked for you, but I am not using Clean master on my L1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same issue with my xpera z5
