after replacement my xperia m i feeling again said bcoz its battery drain soon even just listening music and little watsapp.
sony say its 36hr music playback but i dont think so bcoz withing 30min its battery drain upto 20%.( just music without touch any app)
look withing 38 min its drain upto 59% without useing music just 3-4 time watssapp.
and also i found new small fault its seen in screen shot.. network look full range its reliance sim.. and after lock screen its show insert sim.
and the camera also its not good its burnig in flash and noisey and pixelet the image with high yellow contrass.
and one more thing... what is insert sim problem here are image..
That seems odd, do you have the Xperia M or M Dual? if the later, do you have 2 SIM cards?
I am useing Xperia M single sim..
It could be a bug, you could repair your phone with SUS or PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
ok thanks for help ...:smileyhappy:
Anytime
thaks uliwooly ... now its solve.. thnks again...
