- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ the_breed, thanks for your post. This confirms that I can use OTG with my XMD and I'm sure there won't be any issues using OTG.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Problems such as?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
does micromax have an OTG cable at all???? i guess you r referring to the charger/usb cable. Should do no harm at all i guess.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If it is high voltage consuming then it will charge your phone fast and you dnt have to worry it will not harm i guess.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@basant actually i got it from micromax's funbook.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@the breed..the cable supplied with the M is used for both charging and usb connectivity to PC. Some cables available from other sources sometimes are similar and sometimes support only one of the two utilities. As far as the charger unit goes standard across manufacturers is normally 5V to 5.2 volt output which should be fine with the M. The mAh output varies from 500mAh to 1000 mAh. The higher this fugre the faster your phone battery will be charged. The Sony M charger supplied alongwith the phone is 850mAh and takes about 2 1/2 hours for a full charge from zero. Over 1000mAh output chargers, I would be a little apprehensive of using.
OTG cables all do not work with the M just as all headsets dont. Best to try it out and if it works then there should be no issue for further worry.
