- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia L1 lock screen wallpaper
I've had this device for 2 years now. System update is current.
When I set a lock screen wallpaper, it says'set', but doesn't work.
It used to work just fine.
Can anyone help please.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
First attempt: already tried another wallpaper?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've tried many!
All without luck.
It used to work so I'm at a loss as to the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Then for instance set a wallpaper for both lock screen and home screen.
When that works, set another wallpaper for the home screen.
Another thing to try:
Settings -> apps & notifications -> find Xperia Home -> tap Storage & Cache -> Clear Cache
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am having the same problem with my Sony Xperia L1 and are trying this, but in the settings it only says apps. Wallpaper for Lockscreen and Home screen and no vibration on unlock pattern doesn't work after factory restore.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
As per the version on your Xperia L1, apps is the one you should press on it then you will find Xperia home app.
You can check check here to enter the vibration settings on your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Shall I try force stopping the App?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you mention which app exactly?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
