I've had this device for 2 years now. System update is current.
When I set a lock screen wallpaper, it says'set', but doesn't work.
It used to work just fine.
Can anyone help please.
First attempt: already tried another wallpaper?
I've tried many!
All without luck.
It used to work so I'm at a loss as to the problem.
Then for instance set a wallpaper for both lock screen and home screen.
When that works, set another wallpaper for the home screen.
Another thing to try:
Settings -> apps & notifications -> find Xperia Home -> tap Storage & Cache -> Clear Cache
I am having the same problem with my Sony Xperia L1 and are trying this, but in the settings it only says apps. Wallpaper for Lockscreen and Home screen and no vibration on unlock pattern doesn't work after factory restore.
Hi there,
As per the version on your Xperia L1, apps is the one you should press on it then you will find Xperia home app.
You can check check here to enter the vibration settings on your phone.
Shall I try force stopping the App?
Can you mention which app exactly?
