HI
I unlock bootloader on my xperia l and when i want to start a device there are a sony logo then xperia logo and loading and everything. Phone all the times is loading . sorry for bad english
PLEASE HELP ME
Install drivers. Install them from Flashtool drivers folder.
It's driver issue.
Flash rom via flash tool
i do this and i have that:
10/022/2013 13:22:37 - INFO - <- This level is successfully initialized
10/022/2013 13:22:37 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00
10/022/2013 13:22:43 - INFO - Device connected in flash mode
10/022/2013 13:22:44 - INFO - Device disconnected
10/022/2013 13:22:49 - INFO - Device connected in flash mode
10/022/2013 13:22:59 - INFO - Selected C2104 / 15.3.A.0.26 / India
10/023/2013 13:23:00 - INFO - Preparing files for flashing
10/023/2013 13:23:50 - INFO - Please connect your device into flashmode.
10/023/2013 13:23:51 - INFO - Opening device for R/W
10/023/2013 13:23:51 - INFO - Start Flashing
10/023/2013 13:23:51 - INFO - Processing loader
10/023/2013 13:23:51 - INFO - Checking header
10/023/2013 13:23:51 - INFO - Ending flash session
10/023/2013 13:23:51 - ERROR -
10/023/2013 13:23:51 - ERROR - Error flashing. Aborted
10/023/2013 13:23:52 - INFO - Device connected in flash mode
i install a drivers and i have a same problem
@jakorsen123pl wrote:i install a drivers and i have a same problem
Restart your pc.
Remove your phone battery and wait 30 second and reinsert it again then connect your phone to usb cable.
that works thanks
