whenever I want to take a picture take long to remove it and, when it does, is a photo that came move and overlap to another. Any solution?
i can assure you that your camera is in HDR mode ( jusging by the black spot in bottom left ). HDR takes about 3-4 sec to take one pic.
( more info on HDR : http://en.wikipedia.org/wiki/High-dynamic-range_imaging )
It is advised not to shake your hands much while taking pics in hdr mode. However, since you're saying that it takes 25-30 sec ( which IS abnormal ), i suggest you take a backup of your phone & try either repairing or factory resetting your phone.
Please do elaborate, remove the picture from?
I´m sorry (google traductor)
get the picture*
So the issues is that when you try to take a picture the camera:
1. takes too long to launch/start?
2. snap the picture?
3. save the picture?
Please be more specific
what happens to me is that, when I take a photo takes between about 30 seconds between you and the button I see on the screen, then it comes out as an overlay between two images which is blurry.
Example: (this is supposedly cupcakes with two candles that put 19)
Indeed that's either HDR and/or SCN > night scene/night portrait
