You either uninstall one by one or you could repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
I don't think its malware, most likely it's a third party app creating this, it could be an antivirus app, taskiller, clean master, battery app, ram app, etc.
Boot on >>> safe mode and check if you encounter the same issue, if you don't then its not a preloaded app but an app that you've downloaded
Bridge (for Mac)
